@noflipside
- Jan 24, 2022
Looking to see if anyone has found a replacement rear shock for a 1989 Bravo. OEM Part number 8R4-47480-00-00. Kimpex does not show any or none in stock that I could find. Anything to cross referance to is also appreciated.
Sports Parts Inc. Rear Gas Suspension Shock - 04-281 N7
is an aftermarket one from royal distributing here in canada. no stock atm.
you could use one off of an exell III or enticer as they are the same for some models. the et250/300/340 from 77-91 are the same shock.
excell III lists a hydraulic one
SKU
04-244
Wolftech Rear Hydraulic Suspension Shock
that is about 1/2" longer than the one your sled calls for and is in stock.
kimpex is out of stock but here is their part # SU-04039
