01sxr700
Have a 03 Viper Mountain, cleaned and checked clutches, belt is good and adjusted. Used to pull 8400 all day long now can only seems to want to rev 7800/8000. Anyone have any suggestions. I know I can pull some weight but I shouldn't have to as I never changed anything.
			Check the exhaust valves. Sometimes the cables pull through and the valves stay closed causing a full throttle power loss.
			exh valves would not hurt to check/clean.
when where the clutches last pulled apart and cleaned? odds are new primary spring would not hurt if it has never been replaced.
one or more of the powervalves has pulled the cable thru the end of valve.
			01sxr700
Clutches were just cleaned. My son checked/set the power valves but never cleaned them. Said they looked good, guess I'll remove and clean them.
			Have the same issue with mine, its no longer operating, so was not able to figure it out yet.
			01sxr700
No, valves we just checked.one or more of the powervalves has pulled the cable thru the end of valve.
I've seen a few vipers break the left front engine mount bolts.
			Carb vent hose properly connected to airbox?
			Broken or bad clutch spring?
			adjust them, they cant be operating correctly, thats the exact rpm it will only pull if the valves dont work. usually they are pulled thru the ends from not being removed and cleaned.No, valves we just checked.
01sxr700
No not that.I've seen a few vipers break the left front engine mount bolts.
01sxr700
No, just had clutches apart and cleaned.Broken or bad clutch spring?
01sxr700
Yes, when I get a chance gonna bring the sled in the shop and clean and check adjustment.adjust them, they cant be operating correctly, thats the exact rpm it will only pull if the valves dont work. usually they are pulled thru the ends from not being removed and cleaned.
