4strokesmoke
I was doing some pre snow work on my 01 SRX and wile changing the MAG side exhaust doughnut I saw a drop of antifreeze on the exhaust flange. I quickly pulled the plug and noticed the piston was shiny and the plug was wet. The sled haven't been run since last season with no issues so maybe a head gasket let go at the end of the year before it burned down? any thing to check wile I'm in there? Hopeful I got luckily and just need to replace a few o rings and gaskets.
Anyone ever just have a head gasket go bad with out hurting the motor?
4strokesmoke
Well finally got into the motor and I believe its the impeller shaft seal now. So its time to remove the engine and clean things up underneath.
			How did you come to that conclusion ?
I may have that issue as well, as I had one cylinder that appeared to be burning coolant (piston was clean), even after I replaced head gaskets.
Mine was mag side as well.
			99% of the time it is the rubber coated washer that holds the impeller on.Well finally got into the motor and I believe its the impeller shaft seal now. So its time to remove the engine and clean things up underneath.
Very rare for the mechanical seal to leak.
4strokesmoke
Well their was no rips or tears on the head gaskets and a base gasket wouldn't fail like that. After reading some threads the water pump sounds like a sound reason for the coolant. I'm gonna pull the motor and replace the water pump seals and gaskets for Pease of mind. Heck I may just do pistons and rings wile I'm in there too. The sled has 4 k miles and its cheap insurance unless someone talks me out of it...How did you come to that conclusion ?
4strokesmoke
had some time to pull the motor and further inspection the mechanical seal spring and seal had failed and was letting coolant in. after a quick rebuild she's gonna be back together!
			Triple tippin
Im having a similar issue, new head o rings last season fine all winter first start of this year antifreeze coming out of exaust. Could it really be a waterpump issue filling exaust with antifreeze?
			No, nothing to do with water pump.Im having a similar issue, new head o rings last season fine all winter first start of this year antifreeze coming out of exaust. Could it really be a waterpump issue filling exaust with antifreeze?
Is there coolant just coming out upon start up or does it do it continually while running?
Triple tippin
At first start was a burst of antifreeze maybe a half a quart then a fairly steady mist while idling, last year was first time i had it out in 5 years and did same thing so changed head o rings figured it was from sitting so long and was good all season. Thinking maybe warped head or because i used aftermarket o rings but it was fine all last season. Appreciate any help or suggestions!
			I'd take a look at the head sealing area again. It sounds like its leaking into the engine while sitting.At first start was a burst of antifreeze maybe a half a quart then a fairly steady mist while idling, last year was first time i had it out in 5 years and did same thing so changed head o rings figured it was from sitting so long and was good all season. Thinking maybe warped head or because i used aftermarket o rings but it was fine all last season. Appreciate any help or suggestions!
Triple tippin
Just seems weird that it was fine all last winter but started leaking again while it sat over the summer. I will tear into it and post results. ThanksI'd take a look at the head sealing area again. It sounds like its leaking into the engine while sitting.
Triple tippin
So pulled the heads today but before i started the tear down i started it and got it up to temp was still burning a bit of coolant upon shutting it down i could hear it bubbling in coolers under the footwells guessing it had air in the system but i also noticed bits of black floating in the expansion tank, carbon? Head o rings look to be intact and pistons had a good carbon buildup but 2 of the plugs looked to be washed a bit. Any ideas what to look into next?
			4strokesmoke
Tripple Tippin what cylinder are you finding coolant in? mine was only the MAG side..
			Triple tippin
Clutch side, did the impeller seal fix your issue? I dont see any issues with the head o rings or the sealing surface.Tripple Tippin what cylinder are you finding coolant in? mine was only the MAG side..
							4strokesmoke
Yours should not be a water pump issue due to it being on the MAG side apparently I'm one of the few this happens to... Id get some OEM head O-Rings and run a flat edge across your head to see if its warped..Clutch side, did the impeller seal fix your issue? I dont see any issues with the head o rings or the sealing surface.
Triple tippin
Checked the head seems good, but was definitely questioning the aftermarket o rings so gonna try oem and see what happens. Thanks for the reply!
			Checked the head seems good, but was definitely questioning the aftermarket o rings so gonna try oem and see what happens. Thanks for the reply!Yours should not be a water pump issue due to it being on the MAG side apparently I'm one of the few this happens to... Id get some OEM head O-Rings and run a flat edge across your head to see if its warped..
