The sled has a Holtzman Vari Flow, so the carb vent tubes are fed back to the adjustment knob and then the intake hose is just sitting on the bulkhead under the air box. I have the vari flow set to full rich. I do not have pics, but it is following the standard air box mod. 6 or 7 one inch holes drilled in the top, air box empty except for the center shelf, which also has the 1" holes drilled in line with the top cover's holes. I will check the needle jets. Where is sizing listed on them? I have not noticed it before. Do they just pull out with a soft pliers?
Floats I am unsure of proper adjustment. How do I measure? I assume I just carefully bend the tab the little needle sits on?
