1997 Vmax 500 XT Mid range rough using lots of gas
I have a 1997 Vmax 500XT I purchased new in 97. Only has about 2800 miles on it has has been in storage a lot over years, indoors. Last year was the first time I ever had an issue. Was dieing down after WOT. Came down to the TORS switch on the Carb. When fixing this I noticed a small...
xsivhp
Blubberry is a great way to describe it. Seems to start fine. I'm gonna dig in more this week.
xsivhp
Finally got a chance to look at it tonight.
Reed petals look good except for one. one of the centers does not look like it seals, not sure how important that is. its close, but not quite. One is slightly worn, I have seen them a lot worse. I will replace the bad one.
Both carbs had plugged pilot jet and pilot air jets. Does the way the main jet is installed look correct?
xsivhp
Look at post #35 in that thread for a pic I posted a while back. And the machine in that thread only had 2800 miles.![]()
I have a 1997 Vmax 500XT I purchased new in 97. Only has about 2800 miles on it has has been in storage a lot over years, indoors. Last year was the first time I ever had an issue. Was dieing down after WOT. Came down to the TORS switch on the Carb. When fixing this I noticed a small...totallyamaha.net
IWhat do you think? It seems like there are supposed to b shrouds on the pilot jets or do only the 700s use those?
Thanks!
xsivhp
Is the reed petal where the center one does not seem to close all the way bad? Thanks for all your help on this fellas.
The wound from the $1 a mile for gas ride I took a week ($33 total) for the $12 burger and fries is slowly healing! lol
I would replace the reads.Is the reed petal where the center one does not seem to close all the way bad? Thanks for all your help on this fellas.
No shrouds on the twins.
I've already told you what the problem is, but as we already know there are no parts to solve the issue
xsivhp
Just sent you a message!
those jets where most likely the issue but those reeds need to be replaced. i did the reed stopper notch to mine and it made a noticable difference in starting and performance.
from the tec pages:
This Modifications can be done on the 97 & Up SX700 & 600 Triple Style Motors and the 97 & Up 500 & 600 Twin Style Motors non Power Valved.
See the attached pictures to show what needs to be notched in the reed stoppers. Notch size is 24mm tapered to 18mm wide and 4 mm deep. You can do this on a bench grinder after you take the reed stoppers off. If you do this notch you don't have to get reed spacers. They do the same thing. This mod and the reed
spacers unblock the intake port for a straighter flow into the case on the top side of the reed stopper (Notch goes Up).
Drwe
- Nov 28, 2021
I'm wondering if someone can tell me if a worn reed (doesn't seal in the center opening) can can cause a lean condition? I just did my pre-season carb clean and ran my machine on the stand for 10 minutes, blipping to 4k occasionally, one plug shows lean compared to the other two and I noticed one of the reeds wasn't fully sealing just like this picture. I've ordered one new OEM reed to replace the one tired one but I'm wondering if this was causing the lean condition (not sure how it would).Finally got a chance to look at it tonight.
xsivhp
from the tec pages:
I found two main nozzles in Canada, eh? One showed up last week, the other one is taling the long way.
It came into the US in Chicago (6 days) > Elk Grove Village, St Paul, Champagne, Chicago, Oshkosh, Oak Creek, in transit for 2 days now - I hope they do not lose it!
xsivhp
All the parts finally made it and I got it back together.
A big thanks to all of you fellas I got my 500 running great! Thank you all for sharing your knowledge - Yammi guys Rule!
Awesome!!All the parts finally made it and I got it back together.
