yamawheels
Looking for a rear shock for RX Warrior
Maim
Super Moderator
good luck. the only one i have found is this,
70111-RA
, one as olin no longer makes one and the stock one is non rebuildable.
70111-RA
Axis - Track Kit, Yamaha, Rear Only, Pro Action, RS Rage, RX Warrior, RX-1, RS Vector
$ 1,049.99 USD, one as olin no longer makes one and the stock one is non rebuildable.
yamawheels
Yes we know about this one, just hoping to spend less?good luck. the only one i have found is this,
70111-RA
$ 1,049.99 USD
Maim
Super Moderator
well the new one from port yamaha is listed at $920
otherwise you have to get the relay rods and shock from the rear of a sx viper, sxr or rx 1 and move the centre suspension mount point to match those sleds mount point from the rear on the tunnel. brother and i both had rx war and this was going to be my fix when his shock failed as the war rear shock is almost 1" longer than the viper/rx1/sxr shock. kimpex did make a rear shock for the rx1.
8FG-47480-30-00 | SHOCK ABSORBER |
low slung
Back in 2009 i had Frank at SHOCK-TEC add a hi/lo comp remote res to the existing shock(it was well worn).The system was really nice,cost about the same as a OEM shock at the time......
74Nitro
I just ordered in a rear shock for a 2003 venture 700 which is also 136 suspension.
Open dimension 18.5
Closed 13
Open dimension 18.5
Closed 13
