RX warrior rear shock
well the new one from port yamaha is listed at $920
8FG-47480-30-00SHOCK ABSORBER
otherwise you have to get the relay rods and shock from the rear of a sx viper, sxr or rx 1 and move the centre suspension mount point to match those sleds mount point from the rear on the tunnel. brother and i both had rx war and this was going to be my fix when his shock failed as the war rear shock is almost 1" longer than the viper/rx1/sxr shock. kimpex did make a rear shock for the rx1.
Back in 2009 i had Frank at SHOCK-TEC add a hi/lo comp remote res to the existing shock(it was well worn).The system was really nice,cost about the same as a OEM shock at the time......
I just ordered in a rear shock for a 2003 venture 700 which is also 136 suspension.
Open dimension 18.5
Closed 13
