JKohut
- Dec 31, 2022
Hey all, I'm new to the site and Yamaha ownership.
I bought a 1998 Vmax xtcp 700 earlier this winter and so far have been having a blast with it.
I went to head out for a ride this morning and after checking on the belt I found that it had seen better days so I decided to change it. After changing the belt (new belt is a 8dn-17641-01) the sled is now revving up to 8000rpm just to go 60km/h. 0-4500ish rpm feels about normal then after that it just revs higher without picking up speed.
I checked belt deflection and attached a picture of what I saw. It looks maybe a little low but nothing too dramatic. I'm new to working on sleds so I combed through the forum and found someone with a similar issue but no documented solution so just wanted to throw it out there for ideas and assistance.
Everything worked fine prior to changing the belt, the previous belt did not have any markings left but is the same width & length as the new one. As far as I know, everything is stock.
Thanks in advance!
Thanks in advance!
