cshakespeare113
- Dec 18, 2022
Does anyone know what could be causing a bog on a 1999 vamx 700sx?
super1c
Super Moderator
Did u clean the carbs?
74Nitro
Can you be more specific? Off the line? While cruising? What RPM areas?
I would look to clutches first.
cshakespeare113
- Dec 18, 2022
right off the line. It’s fine when cruisingCan you be more specific? Off the line? While cruising? What RPM areas?
Maim
Super Moderator
is primary clutch clean? how old is the spring in it?
74Nitro
Then check belt height in secondary. If using the 8DN belt normally the cogs are about 1mm above sheaves.right off the line. It’s fine when cruising
Or as high as possible without belt squealing or machine creeping.
You could also use a spring in primary with higher engagement, or shim the stock one.
