cshakespeare113
- Dec 18, 2022
Just wondering what the tallest bar riser you can put on a 03 viper mountain?
Tia
Tia
You should be able to safely add 2" more inches to the current height. You might have to reroute the brake line and throttle cable.Just wondering what the tallest bar riser you can put on a 03 viper mountain?
Tia
Ok. Do you know how long the factory cables are?I have a 1108mm (3.7 feet) cables from spx and don’t know how big of a riser I can put on.You should be able to safely add 2" more inches to the current height. You might have to reroute the brake line and throttle cable.
