Bart Elder
- Jan 28, 2024
Hi guys. I just bought a 2002 mountain max 700 141. All stock. 2600 miles. I’m in Denver Colorado. The machine came from steamboat and I presume it was jetted properly for that altitude, around 9000 feet. I rode the sled once, at around that same elevation. The sled starts easily with full choke when cold, then flip it to half choke to let it warm up. Even after warmed up, I flip the choke off and it dies. Then I flip the choke to half, get it up to 1/2 throttle and she goes. I flip the choke off as soon as she goes. I rode it for an hour like this and it seems jetted properly from about 1/3 throttle to wide open. Again, she won’t idle, but then I flip to half choke and she will . I turned up the idle screw in 1/4 turn increments and that worked for a few seconds, then she would die again unless I flipped to half choke. I turned the idle up one total turn , now I’ll back it out to where I found it. So I’m thinking she’s lean on pilot circuit. Before I pull the carb rack and clean pilot jets, then back fuel screws out 1/4 turn to give it more gas on idling, I figured I’d better ask the experts . Thanks for any help. By the way this sled is in very good condition so I hope I can get the carbs tune properly . Also, even when warm she needs half choke to start and then fires right up one pull.
