03viperguy
so I discoverd that the rough idle is actually it not firing on the pto side while at idle. picks right up with a little throttle. Thinking the pilot circuit is plugged somewhere. I was able to remove all the jets EXCEPT the small ones in the carb throat, they are stuck. Of the 4, only one came out. I did soak the carb rack overnight with all the jets out that would come out, then blasted with carb cleaner followed by 150psi of air. Maybe I will try an ultrasonic cleaning? The only other thing I'm not confident in is the choke adjustment. the book shows the cable needing to be pulled out 1mm, but it is in a cross section that isnt visible, so how exactly is that done? Thoughts anyone?
If someone has ever turned the screw in between the bodies on the throttle shaft, then they could be out of sync at idle.
As for float height, the spring should not be collapsed.
03viperguy
Anyone know if the aluminum steering arms from a viper fit the other proaction sleds like this?
I put them on a Mountain Max build. But I used Viper spindles too.
Splines aren't the same.Anyone know if the aluminum steering arms from a viper fit the other proaction sleds like this?
03viperguy
Huh, I would have thought they would interchange being that it had the taller spindles as well
Now you have me second guessing myself.Huh, I would have thought they would interchange being that it had the taller spindles as well
03viperguy
Opinions on a 1"predator/carve track on this? Found one used like new local for $250
better than what they came with and that is a pretty good price. just make sure to cut the windows open on the track if it hasn't been done. unless snow is excellent, they heat up and drag. had the og ripsaw with the closed windows on my 01 sx500r and when it started heating up the slides, it had trouble pulling the track with the stock snow cross gears. i have cut the windows open with a hole saw for a 1.25" ripsaw from an 04 warrior and put it on a 1990 et400. works great that way.
03viperguy
Good info, thanks!
03viperguy
Grabbed the track yesterday, looks perfect. I think I'll try some screen in studs. Anyone try igrip?
What track?Grabbed the track yesterday, looks perfect. I think I'll try some screen in studs. Anyone try igrip?
03viperguy
Oh ya. That will work out great for I-Grips!Predator/carve. Has the pre molded spots for screw in studsView attachment 67764
03viperguy
Any recommendations on style and amount? I'm totally new to them and see they have a couple stylesOh ya. That will work out great for I-Grips!
I’d contact them. They make version for those track. I’d put one in every holes available.Any recommendations on style and amount? I'm totally new to them and see they have a couple styles
super1c
Super Moderator
X2. I contacted them and they told me everything I needed to know. Instructions, which ones and how many. Great customer service.I’d contact them. They make version for those track. I’d put one in every holes available.
03viperguy
I'm guessing you were happy with the product? I realized the local cat dealer that is a mile from my house is a dealer for them. Pretty convenient!X2. I contacted them and they told me everything I needed to know. Instructions, which ones and how many. Great customer service.
03viperguy
03viperguy
Finally have some snow to try it out on. Struggling with a low speed bog, right at and just off idle. Tried to sync the carbs but the tool wouldn't seal against the pro side to give a reading. Pilot Air screw still at the 1 turn out setting. Thoughts on where to try next? Have a video but it's too large to upload
