Manostihl83
- Dec 14, 2024
Found a few wires rubbed through on the harness that goes under the engine that rubbed through. Repaired those and now it doesent quit but still doesn’t run right. Backfiring and sputtering and gets worse as it warms up. Seems to run the best when it’s cold. Already put new plugs in it. For some reason the temp light keeps flashing 7 times in a row repeatedly
Manostihl83
- Dec 14, 2024
Sled only has uni pod filters and a can with factory pipes
The rubbed wire could have done damage to cdi or mag.Found a few wires rubbed through on the harness that goes under the engine that rubbed through. Repaired those and now it doesent quit but still doesn’t run right. Backfiring and sputtering and gets worse as it warms up. Seems to run the best when it’s cold. Already put new plugs in it. For some reason the temp light keeps flashing 7 times in a row repeatedly
Manostihl83
- Dec 14, 2024
Any way to test the cdi? What is the stator test procedure? What ohms am I supposed to get outve the pickup and stator ?The rubbed wire could have done damage to cdi or mag.
Seven flash is power valve servo motor. Either a problem with the motor itself or an open or short circuit in the wires that feed it.
A manual I’m sure would help.
Manostihl83
- Dec 14, 2024
Could it be the cdi?Seven flash is power valve servo motor. Either a problem with the motor itself or an open or short circuit in the wires that feed it.
Manostihl83
- Dec 14, 2024
Would be nice but I don’t have that luxuryA manual I’m sure would help.
Why not. If you become a VIP we can send you a PDF manual.Would be nice but I don’t have that luxury
Manostihl83
- Dec 14, 2024
If it costs me money I don’t have any. I work on a lot of stuff but haven’t worked on a lot of these sleds so I’m not familiar with themWhy not. If you become a VIP we can send you a PDF manual.
Doubt it. But I know if the leads for the battery hook up are mixed up (without a fuse) it will fry the cdi power valve circuit. Ask me how I know.....Could it be the cdi?
Manostihl83
- Dec 14, 2024
It doesn’t have a batteryDoubt it. But I know if the leads for the battery hook up are mixed up (without a fuse) it will fry the cdi power valve circuit. Ask me how I know.....
Yes I know. But there are leads supplied in the factory harness for battery power which in turn powers the servo motor for adjustment.It doesn’t have a battery
Manostihl83
- Dec 14, 2024
I seeYes I know. But there are leads supplied in the factory harness for battery power which in turn powers the servo motor for adjustment.
