I bought mine used and it always idled poorly ,, ran it for 4 winters pulling a track setter
until one sat morn i decided to look at the plugs .. Jammed packed with Almn.
Upon inspection , someone had probably used starting aid and blown out the Crank seal
, it was also melted on the mag side .. and the oil seal at the injection end wasnt even in the tunnel.
I had been clearing trails the second winter and heard what i thought was snow/ice going in the air duct..
The fan was still turning and we carried on.
The piston skirts were packed in the ports, all rings were pinched and the wrist pin 3/16" into the liner..
This beast went like scoot compared to my 433's. and just didnt idle....
I do no not wish this for you, BUT it was a great story on how tough these beasts are...
When i received mine ,, it had around 10 patch jobs in the muffler as if something came loose
or nested in it and the made the holes to remove a blockage...
Suggest pull pipe off at manifold and see if it draws clear with a shop vacc
.. poor blow out .. poor draw in
Merry Christmas
Ron
