hi all, i have got a 1998 yamaha venture 500 sled that has no spark. this may be long so i appoligize in advance. it ran when i got it but then one day i noticed the tach was bouncing on and off then few seconds later the sled quit running. tried to start it found no spark. i found the mice had a nice meal with the wiring harness so i ordered one from ebay and replaced it, but no help. i checked ground, kill switch was ok but i left it unplugged, key switch is ok, headlight dimmer switch is no good so i left that unplugged also. tested the ignition system and this is what i found;
ignition coil test didnt look good so i replaced it but no help.
plug wire caps needs 5k i have 5.7k, i had a new set i tried, but no help.
source coil (stator) needs 225-275 ohms on brown/blackred wires i have 248 ohms.
pickup coil needs 189-231 ohms i have 208 ohms.
cdi as far as i know has no way of testing it.
it was suggested to change the stator even tho it tested ok. so i contacted a salvage yard in my arrea and ordered a stator and a cdi box. the stator he sent me had 600 ohms on the brown/blackred wires which looks to be worst then the stator i have and the cdi has 3 plugs on it and mine has 2. i contacted them and they are looking for replacement parts. i looked in your tech section but didnt find any answers i needed so my questions are;
1- are these readings i have correct for what the stator and pickup coil need? my manual was downloaded and im beginning to question if its right.
if my manual readings are correct then the stator he sent me might be bad at 600 ohms even tho he said it came off a runing sled.
2- also the wiring harness i got on ebay has a different plug for the regulator rectifier. the old harness had a square plug and the harness from ebay has a flat plug. the wiring colors are the same just different plug. my manual also doesnt show a test for the rectifier, is there an ohm reading i can do or does the sled need to be running to test it? i need to hook up the rectifier so if i can test my rectifer regulater and its bad i will find one for a flat plug but if mine is good i can just change the plug with the old harness.
3- also is there a difference between the flat and square rectifer regulators or are they interchangable?
this sled is getting to be a nightmare, any help i can get would be appreciated...thanks
