srv540
I am pulling the motor in my 01 srx for crank seals and wanted to replace all fuel hose with a good product...I am looking for the sizes I need and a good source for fuel lines?
Not sure if you got your info or not, but this is what I have gathered up over the years.
Tank to pump 7mm ID x 11mm OD
Pump to carbs 5mm ID x 7mm OD
I don't have the in tank line size, unfortunately, but I believe 1/4" will work.
