24vtd
- Feb 18, 2025
Hi, i am having a time trying to figure out this gargling sound out the exhaust is. Its fine at WOT but around a quarter to half its a weird sound out the exhaust like its fluttering until i open it up. i have cleaned the carbs and adjusted the float height and mixture screws, also the Oring's in the seats. All three plugs are tan color. I live in Indiana so there is hardly any snow to test it out and when it does snow i would like to be prepared. I've read on here about reed spacers? and shims for the needles. I'm not sure what im looking for so any help would be awesome.
See if the main nozzles are still available and replace them. The hole where the metering needle slides through enlarges over time causing a rich mid-range condition.
24vtd
- Feb 18, 2025
The main jets right?See if the main nozzles are still available and replace them. The hole where the metering needle slides through enlarges over time causing a rich mid-range condition.
24vtd
- Feb 18, 2025
Im looking at them online and it shows 3 different ones. i can't read the original number on my jets to determine size.
No, the main nozzles. It the long tube that the main jet screws into. They have to be removed from the top. Check availability first and don't put a size in smaller than stock.The main jets right?
24vtd
- Feb 18, 2025
Cool, they are showing main nozzle 2 and 3, 8ch-14141-54-00. Then a nozzle main for a 600 but no 700.
24vtd
- Feb 18, 2025
The 600's main nozzle is the same part number as 2 and 3 in the 700
24vtd
- Feb 18, 2025
8CH-14141-54-00 | NOZZLE, MAIN | 2, 3 | ||
PTO is a series 798 size Q-8
Middle and mag are series 798 size Q-4
I think the Q-4's are still available.
24vtd
- Feb 18, 2025
I just went out and rode it, the PTO carb is running rich the other two are kinda wet. it doesnt pop or backfire just acts like the choke is slightly on. its fine if its pinned all the way across the field. I really appreciate your help on this thing. I had a brand new one in 2000 and it didnt do this at all. this one has right at 4000 miles on it.PTO is a series 798 size Q-8
24vtd
- Feb 18, 2025
What would it hurt if i run the q4 and the needle in the PTO side? I can find those new.PTO is a series 798 size Q-8
At your own risk, anytime I ever tried going down a size, the engine burned down. Did that on an indy 500 and a doo 550.What would it hurt if i run the q4 and the needle in the PTO side? I can find those new.
If you do try it, raise that needle all the way up.(lower clip)
The Viper 700 had the same size across the board, but the PTO cylinder head had slightly lower compression.
24vtd
- Feb 18, 2025
Are the tubes straight thru on the i.d? If so i could have a shop ream the smaller new one out to size. If they are tapered i wouldnt think i could go that route.At your own risk, anytime I ever tried going down a size, the engine burned down. Did that on an indy 500 and a doo 550.
24vtd
- Feb 18, 2025
I think i have it figured out. It only has 80 psi in each cylinder.At your own risk, anytime I ever tried going down a size, the engine burned down. Did that on an indy 500 and a doo 550.
That doesn't explain it idling good and revving out good. Try another tester.
24vtd
- Feb 18, 2025
The neighbor has a compression gauge i can use. Hopefully my gauge is wrong. I have never ran into problems like this before with any Yamaha sled except the 83 vmax.That doesn't explain it idling good and revving out good. Try another tester.
The fact that all three cylinders are reading the same compression would indicate to me it may just be the gauge reading low. Don't forget to do the test with all three plugs removed, throttle wide open, and 5 or so real good pulls on the recoil.
24vtd
- Feb 18, 2025
Can i use the electric start when doing this test? Or should i pull it? ThanksThe fact that all three cylinders are reading the same compression would indicate to me it may just be the gauge reading low. Don't forget to do the test with all three plugs removed, throttle wide open, and 5 or so real good pulls on the recoil.
24vtd
- Feb 18, 2025
Used a Snap On tester and it is around 138 per cylinder. Good old Harbor Junk gauges said 80.The fact that all three cylinders are reading the same compression would indicate to me it may just be the gauge reading low. Don't forget to do the test with all three plugs removed, throttle wide open, and 5 or so real good pulls on the recoil.
