Starter Solenoid/ Relay Cable Location
srt842
South Branch, MI
Hi,
I'm installing electric starters on a 2003 Viper and a 2004 Venom. I have the Venom complete, except I cannot find the 4-pin cable that plugs into the starter solenoid/ Relay. Any help would be appreciated. I found a straight line 4-pin connector, but it would need a pigtail to plug into the solenoid, if that's the correct cable. I was hoping to find a white connector, to plug directly into the solenoid, but I have been unable to find it.
Thanks!
That's what I'm trying to figure out. Some things I've read online imply the white 4-prong connector is wrapped up in a wire bundle. I was hoping to hear from someone that has actually done it to confirm if the connector is there and where it's located. What part finder can you recommend?
i use the parts fiche on port yamaha a lot.
i know on my brother @kirkswims 02 viper, the plug was there in the harness when he added the e start to it.
