sferrall
Is there a way to test the oil pump on this thing? I'm in the middle of doing a top end rebuild and want to make sure it works properly as I'm putting in new cylinders and pistons. Don't want that money being wasted if I'm not getting oil.
Thanks!
Thanks!
BornYamaha
There is probably a better way but I would just put pre-mix in the full tank and fill the oil to the top and make sure you use oil. The extra oil really won't hurt anything. I would go somewhere between 32 to 40 to 1. They should use about 1 quart of oil to 10 gallons through the oil injection if adjusted right. Most of them came alot leaner than that from the factory.
