94 vmax 500 limited to 4500 rpm
extremeviper
Prior Lake, MN
had mouse infestation airbox and under handle bar cover. cleaned carbs checked reed valves and intake boots verified Tors switches good compression wont rev out 4-4500 max no braaaap
after you are sure pipe/muffler is clear, i would check for sticking/stiff clutch and check that the fuel pump holds vac as diaprhams can split with age.
