Has anyone run the Bender big bore pipes on a stock SRX?
If so, do they at least make the same power as the stock pipes?
I just found a set of ceramic coated pipes that I bought years ago and forgot about, and was thinking of using them instead
of the Power Inc. pipes I had on it.
Any info or insight is appreciated
On my 2002 SRX 700 I ran the stock pipes, Ceramic coated Aaen pipes, Ceramic coated Power Inc end dumps, and finally Bender Big Bore pipes. My SRX was a ported 788 with 40 mm TMX carbs and honestly I never saw a huge improvement with any of the combinations over the Stock pipes but the BB Benders definitely were better then stock.
