Sxr 700 broken temp sensor question
mwrev440
So I acquired a 2000sxr 700 in a trade the temp sensor was smashed so I since replaced the sensor with a different sensor that wires up to a actual temp gauge.
My question will the sled run fine with the sensor connector unplugged or will it go into a limp mode, or is there a bypass to plug into the connector, Ive seen the bypass plugs on Polaris sled in the past.
Not sure if it would work without, but, I would just drop the $12 bucks and get a new one.
