VmaX 600
Guys I need to find out what is the biggest stud I can run on a 2000 SXR 700 with stock drivers......Thanks Justin
yamaholic22
if you run too tall of a stud in the stock height track you will have more problems than just tunnel/heat exchanger damage. The studs will just bend and rip out because there is too much pressure on them
VmaX 600
yamaholic22 said:if you run too tall of a stud in the stock height track you will have more problems than just tunnel/heat exchanger damage. The studs will just bend and rip out because there is too much pressure on them
Not running the stock track we are long tracking it. and I want to find out what the biggest stud I can use with out changeing the drivers.
