1989 Phazer: How can I separate the front arms? Bushings appear rusted...
RHodgins
I want to separate the front arms on my 1989 Phazer to add washers and tighten the steering play. Got the ski off easy. (parts 44&45 on the Partzilla Ski exploded view for that year).
When I try to back out the bolt the head stay in contact with one half of the shackle and tries to force the other half off the bolt by bending it outward. Pretty sure the inner bushing is rusted to the bolt trapping it. Of the tthree bolt on the two pivotting arms I only managed to get the bottom one off. Top two have the problem.
Is heat the answer? Days of hitting it with penetrating fluid? Any thoughts? I can't be the first to encounter this.
Thanks in advance.
R
Thanks in advance.
R
try heat, but if that doesn't work, then put the thinnest cutting blade on a grinder or air power cutting tool, and grind through in between the arms. Then get new bolts.
Another idea would be to carefully use air hammer to help break free.
