Settings needed for....
sockeyerun
Test Dummy
Anchorage,AK
Front and rear spring preloads for Viper SX shocks I have installed on my Mountain Max. I have the older (1997) proaction system book, but obviously vipers weren't around then and I would assume the settings are different than the XTC(only long travel KYB's at that time). I'm hoping one of you viper owners would post them from your owners manual. Just want to have the factory settings as a referance. Thanks, Soc
The stock spring settings for the 2002 121" Viper are . . .
Front: 10.24 in (260 mm)
Center: 8.39 in (213 mm)
Rear: 14.51 in (368.5 mm)
If you need the Mtn Viper I should have those too.
Thanks Ding, are these the medium setting #'s ? I am, also interested in the mnt. viper settings, if you don't mind. Thanks again, Soc
I won't be back home (where all my tech stuff is) until next Wednesday. Hopefully someone can answer you before then, but if not I will post then.
