Should I replace?
Quicksticks
USA
Front heat exchanger got pretty messed up from the oversized studs the last owner put in the track, but it’s not leaking. I’d have no problem going through the effort of replacing it since I’m putting a new track and have to pull the motor to fix some wiring but it seems like these heat exchangers are impossible to find. So if it urgently needs to be replaced does anyone know where I can find one? I’ve checked eBay and various parts warehouses to no avail.
You might be able to find one from a salvage guy but there is nothing new. Check with Dale in WI. https://snowmoyard.com/
