Cherrypicker
Bought this a month or so ago, rode it up onto the trailer. Got it home, and it won't fire. I have disconnected the kill switch as well as the ignition switch, thinking that these are "ground switches" if that is the case then I am down to coil, plug cap, plug, or stator. I haven't had a lot of luck testing some of these with multimeters. I am open to any and all recommendations. I think these Yamaha coils of that era, from a Phazer, Enticer, if I hook them up and get spark should work to confirm the coil is faulty. Years ago I hooked a battery up direct to the coil grounding is on the core, and then intermittedly touched the orange wire with the positive contact, and got spark to test. Any thoughts would be appreciated. At 80 yrs, I've forgotten half of what I knew and the remaining half I'm not sure of.
What year? The early models had points and could be as simple cleaning the contacts. Just did one with a bad coil in the stator, but you have to ohm things out with the multimeter. No better time to refresh your skills! I always work my way out from the stator as the coil, the kill and key switches arent prone to failure. I should have ohm specs, model specific, if you want to go that route.
Good on you for playing with these toys, I hope I am still around at 80, 15 more trips around the sun
