sasksxrider
switching 99 sx 700 to 8 tooth antirachet drivers just wondering if any body new the measure ments from each end to the outside of the coilarrs on the new drivers
riverman
- Feb 1, 2004
Easy with a ruler and straight edge. Before you remove the two old center drivers make a mark on the shaft dead center between the two. Lay your track out and using the mark, center the shaft between the windows. Set your new drivers in the track windows and use the straight edge to transfer the outer edge of the drivers to the shaft. Press on.
grapeape
I have some numbers here, but different drivers have different numbers...
