sockeyerun
Test Dummy
How many RPM's does each shim raise the engagement point when added to the primary. Thanks
MountainMax
I would like to know this also, there are different thickness of shims too, and if you install too many you can bind the spring right guys?? what is the normal or max before this hapens, or how can I check binding?
