I am going to fab up a sled stand to keep the track off of the ground for maintenance and storage. It would be nice to not have to lift the sled up and set it on the stand. Their are many different ones you can buy that allow you to, in a sense, jack up the rear of the sled.
http://www.powermadd.com/pdfs/power-lift instructions.pdf
I am sure I could design one with some trial and error, however, if plans are available, while reinvent the wheel.
HAVE ANY OF YOU DESIGNED ONE OF THESE?
DO YOU HAVE PLANS TO SHARE?
98srx6
Somebody just posted a picture of their design either here or @ TY.net, if you look around a little you'll find it, and maybe that person will fix you up with some specs on their design.
Derek
Just bought two of these. Might be a bit short. Probably make a higher wider base for better stability.
Kgmz
I have a stand similar to Derek's. It has plenty of height for mountain sleds and the bumper bracket is adjustable. Mine is from Mountain Performance, but I am going to build a couple more like it myself.
Oultman
here's a lift I remember getting awhile ago, maybe on this site, I can't remember. I still haven't go around to making myself one.
Oultman
2nd pic
yamageek
go to www.sledlift.com they have a blue print or lifts you can buy
