Bearings
snow3
Central Pa
I was wondering how many miles you have gotten on jackshaft and drive bearings on your machines before they go bad? My experience has been when they get between 5-6000 miles on them they usually go bad.
bearing
If you have that magic 5-6000 miles I would say it is cheap insurance, because they dont go so well when the bearing quits...lived that.
Like all parts-- someone will respond that they have 2million miles on the stock bearing,(like that geek in snogoer with 10k on his rx1) but I would change it if you go anywhere besides the back yard.
For that matter - check all bearings in your skid as well.
Good luck, and do the snow dance or we will all be changing skid bearings from the mud holes.
I just replaced mine at 8000 km and they were on there way out ,I could feel rough spots when I turned them in my hand. Jack shaft and bottom drive on clutch side
Brad
when you changed jack shaft and drive axle bearings, like i did when i replaced track, should we be worried about needing to re-align clutches?........Reaper
