studs..
srxxx86
Ok.. I want some new studs. I want very sharp ones, not the carbide crap everyone is getting. I realize they will wear out.. boo hiss I don't care.
Should I run straight chisels, or straight ice pixx, or what?
I have a 4 on each bar up the middle pattern (192), so i was thinking the inside 2 be pixx and the outside 2 be chisels (96 of each)
was leaning towards stud boy. Let me know, thansk!
PS: I have a 1 inch camo track.. what length should i get em?
chisels and ice pics are sharper for a little while, then they dull a whole lot faster. dont be surprized if the carbide guys kill you in a race.
Why do you want extra sharp picks? Are you planning to run over stuff and puncture it?
lol, i found a deal on carbide tipped extreme max studs, 1.15" in length, would those be the right length for my track?
go mega bites
mega bite studs are the best of both worlds, they hook almost like a chisel with the flat surface but last a bit better with the carbide inserts.
I run the 1.25 inch Extreme Max studs in my 1" Camo. Extreme Max studs tend to run a bit shorter than other brands, so it was recommended that I went with the 1.25s. They have worked great so far, and I'm not sure anything less would do the trick.
