Anyone Try The New Super Tip Weights??
Bushman
Magic, SRXspec has been the only person I have seen talk about the S/T weights. They look like you would be able to load them to fit your every need.
I Need More Than One Opinion.
Like When You Go See A Doctor, It's Nice To Get A Second Opinion.
Doctor Allen Must Have Some Patients Out There Some Where!!
I played with them. Got em working about the same as HH,s. Nothing special....my wallet is $200 lighter! HH,s are a lot easier & quicker to tune.
That's The Opinion That I Needed!! Thanks Turk!!
Anyone Else??
Anyone Else??
Srxspec
Your #1 performance shop!
You'll find more responses over on RX1.info Magic. All our sales have been Vector & RX-1 guys.
Srxspec
Bluebyyou2000 (RX-1 Turbo), Jtssrx (RX-1), Buster696 (RX-1 Turbo), Milljk (Vector), just a few who are running Supertips. Also yamadooman (RX-1) has our demo set currently as well. Easier to tune than the Heavy Hitters (you only have to remember either 1 gram or 7 grams instead of what all the different washers weigh like in the Heavy Hitter) and better low & top end results. But you already know my opinion. If you're around tomorrow I'll give your cell a call!
Thanks Allen!! I Will Take A Look.
Srxspec
Also bjniceguy and Superstroker....just a few that I remember off the top of my head!
J
jtssrx
Guest
the super tips work well. They instanly out ran my Heavy hitters with allens setup. With a little tuning I was able to get my brothers RX-1 running HH to run with the Super tips but in every race I still instanly jump him. hte super tips seem to accerate quicker!!! So I pull out in front of him then we stay even from that point.
Jay, Were You Running More Or Less Weight In The Super Tip Than The Heavy Hitters??
J
jtssrx
Guest
Not sure I'd have to weigh the HH to see. I was running 60 gram ST's. I'm thinking I was in that same range with the Heavy hitters
You will generally run more weight in the Supertips then in the HH,s. I found I had to run 3-4 more grams on average with same secondary set up , same primary spring to achieve the same result. This is comparing 48 gram hh,s to 50 gram supertips.
Srxspec
Exact opposite findings here....I've always been 3-4 grams less on the Super Tips than the Heavy Hitters with everything else being the same.
Ooops..ya..What Al said. I just reread my clutching notes & I found that hh,s needed more mass the the goofytips!
Srxspec
Hey Turk, is the old age catchin up to ya?
So The Super Tips Have A Better Profile Or I Should Say A More Aggressive Profile.
Now How About This Guys??
How Do The 8bu-00 Compare To The Super Tips.
I have spent a lot of time this year with 8bu-00,s in my SRX & have found them to run the most consistent & with a low finish angle on the helix with lots of tip weight they still pull great top end. I have talked to a couple of local real good tuners & they allways go back to the 8bu,s. They just don,t have the snappy backshift but neither will HH,s or supertips when set up for drag racing. I dunno.....I just keep going back to 8bu,s & in my tuning parts I have heelclickers(3rd gen & pivoting arm) heavy hitters & supertips.
Turk - I went to see the 06s last night in Portland Maine. I was hoping I might get a look at the new factory weights that have 3 holes for rivets. Unfortunately - there weren't any to be seen without tearing apart a primary (no I didn't ask if I could). Who knows - maybe they will turn out to be a good "poor mans" Heavy hitters. The sleds are awesome!!! I've never been tempted by the RX1 - but after sitting on the RTX - well, next year could be the last season for my SRX. By the way - the 8DN20 setup continues to kick *** ! Thanks again.
Bill in Maine
Bill in Maine
knuckles
Has anybody tried tapping a stock Yamaha weight so that they can use bolts and washers instead of rivets or are the stock weights to brittle??
