Reed Gaskets
greg
Ajax/Apsley Ontario Canada
Does anybody know if the reed gaskets are re-usable on a 2000 SX700R or do they have to be replaced. I plan on doing the reed notch tomorrow and want to know if I need to pick-up new gaskets. Thanks,
generally not a problem, just to be safe, keep them matched and indexed to each reed block and re-torque to factory spec. don't overtighten. 8lb-ft sticks out in my mind for some reason.
Thanks everyone,
did them these weekend and it worked so well I ended coming out of a corner to hard and ended up in the rubarb patch. Luckily, it was just my pride that was hurt.
The rubber stayed down and I stayed on. I went 3 feet off the trail into the rubarb. Luckily, it wasn't time for a mid-trail track inspection. It's amazing how easy it is to inspect the track when it's upside down.
In all seriousness, the reed notch and changing the needles to the 2 1/2 position made an incredible difference on throttle response. It used to be 3/4 throttle coming out of the corners now it is 1/3 throttle.
Thanks for the tips.
