I found this on the V-Max 4 website and has helped me tremendously, so I thought I would share it here. This is a swap of an 03' RX-1 skid into a 96' V-Max 4, but should help in any old V-Max chassis (proaction or not). Please make note that the newer proactions are narrower, so spacers must be made up. Hope this helps someone.
Great post!! Ejcamaro...that might come in handy in the near future...CP
You may have to expand the pics to see the writing a little better, as I had to shrink them to get them on here. You can read up on how to do something, but it helps so much to be able to see a picture of it done with the measurements right on there.
Make very sure you get your holes exact. I missed by 20mm on the rear hole, and it binds the suspension up bad. Maxdlx
20mm???? what was you usin fer a tape???
good post im gonna need it as we are puttin a viper rear into an et410. its all about the powder
sandmanmike1
Has anyone put a warrior skid in a long track 94-96 vmax st. Or is there any other options for me?
It all had to do with the taper of the tunnel. If you use drop brakets it can happen. Maxdlx
Wow, I see my work beat me to this site. I just signed up on TY but have been on the Ultimate Vmax 4 site for a long time. On rear suspension swaps, one of the areas that is often overlooked is the tunnel reinforcement. I have seen tunnels crack due to the different locations of stress loads of the replacement skid.
No way
Thats very strange, I just signed up on the V-Max 4 website last night....kinda scary if you ask me.
EJCamaro, we'll obviously meet again. So, you getting one of the big Max units or just interested in them?
I've always been fascinated by the 4 cylinder two stroke sleds. I've been looking for a nice 97' with very low miles for the right price.
Those '97s are not easy to come by - probably because there was not that many made. I have/had one with 1060 miles on it. A fellow in Alaska plans to buy it from me. I also have a '96.
I have 2 SRXs. Their skids measure the same as the 97 Pro Action under a VX800.
sorry to open a old thread but will this work on a old phazer like 89???
ole_boxer
suspension upgrade 1995 vmax st
What is the best skid to use for the easiest install
ole_boxer said:What is the best skid to use for the easiest install
Can't help you there - maybe whatever you can get the best deal on. If you're looking for softer going on the bumps, I see quite a few guys liking the SCs and Polaris long travels. Can be a lot of effort and expense to retrofit older sleds.
jimzachwl
I hope this is the right spot for this post. If not I apologize. Here goes. I have a 95 vmax 600 all stock and have a skid out of a 96 vmax 600xt. The pics above are great, but the skid being used looks a little different then what I have. I guess what I need to know is. Will these measurements work? If not would anyone have the correct measurements. Thank you in advance.
YamahaVmax600
hey how do you adjust the rear bar things for the proaction suspension? because i put one in my yamaha vmax?
staggs65
YamahaVmax600 said:hey how do you adjust the rear bar things for the proaction suspension? because i put one in my yamaha vmax?
do you mean the transfer rods?
http://www.totallyamaha.net/forums/showthread.php?t=34503
