These things a good mod? Where specifically on the viper do they go? I'm going to be digging around the sled this summer and wondered for the $20-40 if its a smart mod. Also I assume it transmits more vibration to the sled but is it too bad? Thanks
They are great for keeping the clutches aligned and the motor mounts and bolts from breaking if you ride hard or jump a lot. I only recommend the Yamaha part along with an SRX front engine mount. If you only trail ride and aren't looking for that extra 1/2 mph, then they are likely not worth it for you. The Viper engine is so smooth that the extra vibration is minimal.
snoden700viper
I agree with Ding....I installed one on my viper and could'nt tell any difference in vibration.
yamaholic22
yea they are a real good add-on. Keep the clutches more efficient by keeping them in line, makes your belts last longer, and more power is transferred underacceleration, and it is easier on the pto bearings and jackshaft bearings, as well as clutch bushings and buttons. Any increase in vibration will be very minimal.
TimeBomb
i put the torque limiter on my viper after i broke a motor mount bolt this year, i would def. recomend it. there is no difference in vibration, the limiter has rubber bushings so that will absorb what very very little extra vibration there is. they are installed right behind the primary clutch. very easy to install
yamaholic22
timebomb, did you install the srx style or an aftermarket adjustable one?
TimeBomb
i don't know what the srx style one is. i got the one that says sxviper torque limiter kit in the accessories catalog, maybe its the same thing
yamaholic22
is it adjustable, or just a ball joint with rubber mounting on each end?
TimeBomb
non adjustable
viper paul
- Jan 18, 2005
have a new one 15.oo shipped p.m.me if instered
yamaholic22
yea that is the srx style then, the aftermarkets are all adjustable
snoden700viper
What would be the purpose of it being adjustable? Can't figure that one out.
yamaholic22
you know that is a good question. The only thing i could think of is that there are slight variances in every sled, and the adjustment would allow you to get the center to center perfect for your specific application.
snoden700viper
That makes sense. Thanks!
03viperguy
do it, well worth it and as everyone else has said, no vibration difference. I have one and didnt notice a chang ein vibrations at ALL!
