x2ryder
Will the stator from a 2002 srx 700 fit on a srx 600 bottom end?
no it will not, i have the stator you need though, i can send it to you for 75 shipped in the us,
Junior
I'll confirm that
the stator switched in 2000 when they updated the ignition, BTV's not just trying to push stuff on you, and $75 is a good price.
Danger Dog
Yes but you can make a 98-99 flywheel and stator work on the 00 and up cases. I just got done doing it yesterday. It would probably be easier to do it the other way around. But I would buy the stator from BTV as that is a good price.
x2ryder
Well I have the stator I was just going to have the cases ported on the 98 with the 780 kit and leave my 2002 motor alone. Is there much of a gain porting the cases on these machines? If not I will just put my 780 cylinders on my 2002 bottom end. Thanks
yamaholic22
there is a couple of horsepower to be made from porting the bottom end. I dont have any experience from doing it, but Junior says it is a very time consuming process, like more than a day's worth of work. Probably not really worth it for trail riding unless you have a lot of time on your hands.
Junior
ya, it's a pain in the ***, the way I do case porting I need to port the cylinders to tho, I open up the base of the transfer ports, I THINK most other guys do case porting the same as that, but I dunno for sure how everyone does it.
in anycase, if it was a motor ported the way I do it, you won't be able to bolt unported cylinders to a ported case. or you can bolt it down, but you'll lose power 'cause the ports wont line up right, once they're ported they're stuck with each other.
