snoden700viper
Need to replace the track on the 02 Viper. The sled is all stock with 8500 miles. What are the pro's and con's of fully clipped and every third. Looking at the 9830 and 9837 1" track, but looking for any suggestions as well. I trail ride 99% of the time out riding. I will use the existing studs in the new track in a 120 pattern down the middle.
Snoden
Snoden
yamaholic22
if weight is important, you don't run extroverts, and you always ride in good snow cover, go with the every third clipped. Fully clipped is only really necessary if you run extroverts, and they are a little heavier because of the extra clips. The every third seem to take a little time to "break in" the rubber so that you can get full top speed, because the rubber is kind of sticky at first, but once its broken in top speed is just as good, maybe even better. I would go with the every third.
n2oiroc
i concur!yamaholic22 said:if weight is important, you don't run extroverts, and you always ride in good snow cover, go with the every third clipped. Fully clipped is only really necessary if you run extroverts, and they are a little heavier because of the extra clips. The every third seem to take a little time to "break in" the rubber so that you can get full top speed, because the rubber is kind of sticky at first, but once its broken in top speed is just as good, maybe even better. I would go with the every third.
nailsandrails
Is there a different part number for the 9830 fully clipped and every third?
yamaholic22
yes, the 9830 is every third, and the 9837 is every. Otherwise the tracks are the same.
nailsandrails
Ahh...Thanks!!
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
- www.cbperformanceparts.com
700 or Snowdust if you are interested in the 9830 or the 9837, I will PM you with some end of the season prices.
snoden700viper
That would be great 2000srx, send away. I'm always looking for a great off season deal.
nailsandrails
Have any of you guys used this track? http://www.maxxperf.com/Kimpix_Track.htm
I rode and XTC with it this year and was impressed. It was not studded, but hooked up very well.
yamaholic22
2000srx, can you send me a price on an 9830? Thanks
snoden700viper
Snowdust that looks like a nice track. I have a kimpex track on my 97 SX (installed in 9
with 96 studs down the center that has over 8,000 miles on it and it's still like new money. I do like the pre-drilled holes from the manufacturer. Can one leave the outer belt holes open (center studded) and run the track safely with no future problems?
nailsandrails
You sure can. I was impressed with this track. I am hoping someone else has used it and could compare to the 9830 that I am going to buy before next season.
yamaholic22
i dont think it would be any better than the 9830, and the 9830 is quite a bit lighter and easier on the pocketbook.
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
I have PM all of the people that needed a price on a new track
yamaholic22
2000, clean out your pm box
2ooosrx
- Oct 2, 2004
- Gurnee, Illinois
It's clear!
