03viperguy
timebomb, are you keeping your sled? thought you were selling it....
03viperguy said:timebomb, are you keeping your sled? thought you were selling it....
sucks about the burn down...any mods done to it to encourage a burn down? or just bad luck, gas, etc? and where in NH? I am in altonKatahdin said:I have an '03 ER with 3,950 miles, on my last ride this year had a burn down on the mag side, before that just had moisture problems inside the speedo and a bent radius rod.
03viperguy said:at the welds mostly. the cross members are welded and tend to flex and flake off the paint prior to snapping. as before, hope this helps you out!
