sxr-700:
srxspec is the fastest of us on the grass without a doubt, you should listen to whatever advice he gives you.
however you should realize that certain stuff you are doing here wont pass tech if they check, the head gasket and read notches won't pass, realistically the odds of them measuring the head gasket isn't that high, but the reed notches, if they tear you down that far they're sure to find. I've never seen them check for boring in a silencer, so you're probably ok there, but it's technically illegal. the SRX shocks is abit of a grey area from what I know, but it's something they're pretty likely to notice.
if you have adjustable transfer rods on the sled you'll have to take 'em off or you'll be DQ'd forsure.
you're also gonna wanna chain down the front end to it's minimum 2" of travel, the way I usually do this is with actual chain, sink the top shock mount bolt thru a link then snug it back down (with a washer on either side), now loosen the shock off as far as you can (till the spring is floating) get a helper to sit on the front bumper to compress it down to the bottom, then let the front bumper lift 2" this is the height you want, now I usually use the top radius rod bolt for the bottom end of the chains. go to the closest link to 2" but err on the side of caution with alittle more than 2" of travel.
now tighten the shocks back up, I usually set up a block of wood under the front bumper that's at the "bottom" of the stroke, then keep tightening until my helper and I can't make it hit the block by bouncing on the sled, then back it off until we just barely can.
you HAVE to be sure that you can demonstrate to the tech guy that the sled has 2" of travel both front and rear, so make sure that you'll be able to duplicate this bottoming procedure infront of the tech guy if necessary.
if you have them available I'd make sure you have a 19 and 20 tooth top sprockets, and 40-41-42 bottom tooth sprockets, between those 5 you have enough combinations you should be able to set-up for about any track.
to check if you're gearing is right you mark the clutches with a magic marker, then make your pass, be sure to shut down right at 500', don't hang onto it for an extra 30' after the finish line in testing. the marker should be completely rubbed off, or more likely your clutches can't make full shift and it'll be about 1/4" of marker left on the very top of the clutch.
as far as clutching goes I don't have my notebook here, so I can't help ya, I have a set-up somewhere for an SX700, should be pretty close, but I'll warn ya now that altho that SX700 would beat vipers, it wouldn't beat F7's, and that's a couple years ago when they where brand new, they sure havent' gotten any slower.
if memory serves, with the head gasket squished down that motor should rev about 8800rpm, you're gonna wanna engage at 5500rpm (since that's the maximum allowed) I usually swing my tach so that 5500rpm is just a hair above left, usually 5300 or so is left, that's where I hold the RPM at waiting for the light, makes it easier to watch with the corner of your eye, since your concentration should be on cutting a good light first, and on holding RPM second, but if you clutch bump you're screwed, and I don't believe in holding the brake since with a hydraulic braking system you'll be 10' down the track before it's fully let off.
you should also ALWAYS burp the sled on the line before you launch, to get the secondary completely back to an unshifted state, if you drive to the line and hit the brakes to stop the sled the secondary won't be completely closed, it's like launching the sled in second gear, it's just gonna slow you down, and if you're testing it adds another variable, which is the LAST thing you want.
I'll give my dad a shout and get him to check in my notebook for that set-up, hope this info helps ya man, but I think you're better off running backyard races, unsanctioned stuff. it takes a SERIOS investment of both time and money to be competative on an official circuit, for those guys that say "drag racing takes no talent" I challenge them to go out to an official event and run within 10mph in 500' of the fastest sleds in there class.
cheers
-Iain
