D deekersrx700 New member Joined Jun 24, 2005 Messages 310 Age 51 Location Val Caron, Ontario Jun 25, 2005 #1 What is the benefit of using smaller rollers if any?
T Turk TY TECH ADVISER Joined May 2, 2003 Messages 2,806 Jun 26, 2005 #2 They make your primary weight act a lot more aggressive & heavier then it actually is.It also lowers engagement. Makes a bigger diff on low end then top speed
D deekersrx700 New member Joined Jun 24, 2005 Messages 310 Age 51 Location Val Caron, Ontario Jun 26, 2005 #3 Will you lose top end with the smaller rollers?
D Danger Dog Member Joined May 14, 2003 Messages 543 Age 53 Location Vermont Jul 1, 2005 #4 deekersrx700 how do you figure?
yamaholic22 Active member Joined Oct 23, 2003 Messages 5,276 Location Iowa Jul 2, 2005 #5 if you do lose any top speed it would be very minimal, and could be corrected by slight setup changes
