deekersrx700
What is the benefit of using smaller rollers if any?
They make your primary weight act a lot more aggressive & heavier then it actually is.It also lowers engagement. Makes a bigger diff on low end then top speed
deekersrx700
Will you lose top end with the smaller rollers?
Danger Dog
deekersrx700 how do you figure?
yamaholic22
if you do lose any top speed it would be very minimal, and could be corrected by slight setup changes
