n2oiroc
will a 1.5" track clear the front heat exchanger protectors on a viper if i run 8 tooth drivers? i know i have to remove the tunnel protectors, but i really dont want to remove the heat exchanger protectors in case i want to go back to a studded 1.25". thanks
yes it will clear
n2oiroc
woo hoo! do you know by how much? thanks.
yamaholic22
not by too much, it'll be pretty tight
n2oiroc
dont you have a 1.5" under your sx? how is it holding up? how about hifax wear?yamaholic22 said:not by too much, it'll be pretty tight
n2oiroc said:will a 1.5" track clear the front heat exchanger protectors on a viper if i run 8 tooth drivers?
With 8t drivers you can run a 2" track
yamaholic22
it is holding up but hyfax wear is definately a little worse with the tall lugs. This track HAULS on the loose to semi-packed though, really unbelievable.
sorry misread the post.
