1.5" with front heat exhanger protectors?
n2oiroc
milwaukee, wi
will a 1.5" track clear the front heat exchanger protectors on a viper if i run 8 tooth drivers? i know i have to remove the tunnel protectors, but i really dont want to remove the heat exchanger protectors in case i want to go back to a studded 1.25". thanks
it is holding up but hyfax wear is definately a little worse with the tall lugs. This track HAULS on the loose to semi-packed though, really unbelievable.
