I run a 700 with pipes, and have found it ate more plugs at warm up as well. Like the single pipe it is cold blooded, but now the problem is compounded. Let it warm up for a minute or two, but use ONLY the choke, and no throttle. If you hit the throttle--you better start rolling or it will load up in a minute. I suggest (depending on temp) let it warm up for a minute, and then start creeping it around like 10mph or so. If it bogs or spits--hit the choke (on then off) let it build some more heat and repeat. DO NOT get into it or you could cold seize or back fire to the point of damage. At the same time you can not let it just sit because it seems to load up for the amount of time it takes to heat in. lastly - dont punch it then let it idle--(take it down slow) other wise the full gas/oil wont hit the motor until you are back at idle (it has a delay based on gas line etc)
You will figure it out, but dont assume you are to rich and re jet, because that is probably not the case. (ceramic pipes will help a touch)
