I was looking thru the posts here and noticed a lot of Yami owners like myself are having trouble with fouling out plugs on startup. I have an 02 sx600r which I got last year and at the beginning of the season last year I kept fouling plugs on startup but never fouled one after I had been riding the sled. After a couple of weeks I finally got the hang of it and I ran the same set of plugs for the rest of the season with no problems. Now this year I have taken the sled out twice and fouled the plugs both times. My procedure is full choke on start then immediately to the middle position for 5 or 6 seconds then choke off and I don't touch the throttle. I then let it warm up for a few minutes and go and if I am able to get on it right away it always clears out and I'm set for the day, however occasionaly I don't have an open path to clear it out. My sled is stock and is not using excess oil or gas. I know it is a startup problem because after I foul the first set of plugs on startup I then put a second set in and the sled fires up perfect and runs without a hiccup for the rest of the day.
