bar riser woes, PLEASE HELP!
03viperguy
Alton, NH
I put on a bar riser last year, only a few weeks before the snow melted. I LOVE it, only a 2" rise, perfect without being ape hangars (I ride seated all day) now, the problem comes into play being that the bolts that hold it in.........one of them was cross-threaded from the factory (came out REAL hard) and I want to know how to fix it. the bolt goes in about 3/4 the way, then binds. I rigged it so it would work for the few hundred mile I rode it and just took it easy. any ideas? anyone know what tap will work? thanks for ANY tips help! you guys rock the internet world. I realize that the MOST during the summer months when I visit other sites and listen to people rag on others for their cars etc. :rocks: :rockon:
I dont recall the bolt size off hand, but you will need to get a tap that matches the bolt and thread size, and run it through the hole.
anyone out there know the bolt sixe and thread of it? I am headed north in about a week and thats where my sled is. would LOVE to get it straightened out while I am there! thanks!
You should be able to take the bolt out real quick and size it and run down to the Home Depot in Littleton!!!!!LOL
true :) headed to pittsburg this year bucky? in like the nearly 3 years I have been here I have STILL yet to ride with ya :) been still thinking of leaving the viper for a polarbus?
ill pull out one of mine and check the thread pitch at work tommorrow for you. im thinking 8x1.0.
Don't jerk around with it. My super tall PowerMadd 2" articulating base and 4" riser came with instructions to drill out the factory holes and bolt it on. After snapping off a few items in my day. I will never raise the bar without bolting through again (also make sure your steering post head is like the SXR head and re-inforced, the SRX head is nasty and will kill you if you raise it, it's a thin plate welded to the pole). IMO it's the only way to insure you will not pull the bars off when you whack the flipper or go over a nice launch. Don't forget the locktight!!!!!! I'll post some photos if I get around to it. Doug
riser
I was thinking of putting a 2" riser on my 99 SRX so I have more leg room.. is it this possible without having the bar pull through? what can be done? thanks
Yes its possible, I have 2" on my srx. If it would make you feel better you could reinforce your steering column (I did). Do a search on the forums for directions on how to do so.
Hi, I did a quick search and couldnt seem to find much on reinforcing the steering column for an SRX. Could you give some pointers on what you did? I really NEED the 2"
riser but I dont want the bars pulling loose either. Were the cables long enough and what brand of riser worked for you? Thanks much for your time.rippy
on my viper I used ROX, and I LOVE them! I am up north now with the sled, but I TOTALLY forgot to bring a tap set lol! o well, isnt the first and wont be the last tim eI forget something :)
Basically I have a piece of pipe (with an o.d. that is very close to the i.d. of the column) that is "pounded" down into the steering column and welded at the top.
I used throttle and oil cables off of a 03 mm. They were long enough for my 2" riser and bars that are 6" wider than stock.
I made my own riser, but any brand should work fine.
Nysxr700 Is Correct!!! Do Not Put The Bolts In Threaded...i Have Broke Mine 2 Times Before I Drilled Out The Holes And Bolted It...use Grade Eight Bolts Or Stainless....i Have Yet To Brake The Bolts In 2 Years Of Riding....
