To anyone, Do not, I repeat, Do not use yamalube R for snowmobile premix if you are out riding and need to do the old gas station fill it up, put the gas in then shake the sled to mix it. I did this one time when it was about 15*F. All the oil went to bottom of the tank in a big thick glob then got sucked into the carb with nearly no gas in the mix. It went about a 1/4 mile out on to the lake then stalled with the all oil mix. Had to be towed back. The yamalube R is just too thick. Not sure about regular yamalube. Never tried it. If the non-synthetic even still exists. I have beed using Polaris pre-mix oil made specificly for old sleds at 32 to 1. Been working great.
