do you have measurements from the ends of the shaft like above, except instead of the inside edge could you get measurements to the outside edge of the hub (the base, banded part) its the closest thing to the ends of the shaft, tape measure should touch end of driver and lay on shaft. i had my polaris dealer do mine and want to double check the work, it doesnt look right and i really cant measure the way you described when they are already on. thanks
