auji700triple
The Head gasekt, all i have to say is this.. When poeple peel off layers of their head gasket what are they acheiving fgor? wat are you accompishing when u peel off a layer??? i am runnin a bender Opti-cool head gasekt with tripple bender pipes... would u suggest me Peeling one off? or Keeping that the way it is??
*99sRx700*
l
l
idiot
l
l
idiotRemoving layers of the head gasket increases compression and decreases squish. This can gain a little power, and gain significant responsiveness. You will want to ensure that the rest of your setup can handle this, including the type of fuel that you run. If you are running an opti-cool gasket, I would leave as is.
Leave the opticool gasket as it is. It requires all three layers to function properly and to get the right amount of water flow to each cylinder.
auji700triple
alright thanks for the replys, and rc hahaha its ok i wont pal
